Rack Mount Handles
Hi, everyone,
What about the sansui AU-519, TU-519, SC3330 rack handles parts number ?
please thank's
As 4-2-7 said.
And also see the previous info from HiFi 1991:
5 396 340 10,0 cm AU-517/717/719/819/919, TU-717/719 16,8 cm
5 396 720 10,0 cm TU-417/517/519/919, TA-300/500, AU-417 16,8 cm
72 963 600 10,0 cm SC-1330/3330 16,0 cm
Have fun
-John-
I have another few questions...
#1 ...Can i change my my power cord 2/18 awg for 2/14 awg in my au-519, tu-519 ?
Is it possible to burn something inside ?
#2 ...Also , i have a problem with my bass ( level -6) and treble ( level +8 ), my speaker are Mission 700 ...8 ohms ?
I clean everything with Deoxit dn5....Ampli, tuner, tape and speaker.
#3...I have a subwoofer onkyo with only one rca plug on back side and a gain button, how can i plug it in to my au-519 ?
what can i do ?
Thank's......check photos !
View attachment 1869164 View attachment 1869165
Adding CA-F1 and SE-9, almost complete:
Code:
 part number   hole placement                     Model                     high
    72 963 900  horizontally   CA-F1, RX-50                                 6,0 cm
     7 726 700     4,5 cm      TU-S5/S7/S9 (B)                              8,3 cm
     5 396 350     6,6 cm      AU/TU-117/217/317, AX-/MA-7, (RA-900? RX-10 11,0 cm
     5 396 700     6,6 cm      AU117II/217II/317II, SE-5, (RA-900? RX-100? 11,0 cm
     7 712 200     8,0 cm      D-350M/550M (B), SE-8 (B)                   12,8 cm
     7 667 900     8,0 cm      AU-D5/D7 (B)                                14,8 cm
     7 767 900     8,0 cm      SE-9 (B)                                    14,8 cm
                      ?        RX-150                                      15,0 cm
     xxxxxxxx      10,0 cm     SC-2110/3110                                16,8 cm
     5 397 100     10,5 cm     SE-7 (B)                                    15,9 cm
     5 390 080     10,5 cm     SC-1110                                     16,0 cm
    72 964 000     11,0 cm     SC-5330, BA-F1                              18,7 cm
The SC-5110 got no rack handles!
I know this is a VERY old thread but thought I'd update some info. I own an Se-7 and an SC-1110. The SC-1110 came with handles, and they fit the SE-7. Note that the unit height of both (faceplates only, excluding any legs) is 149mm (150mm) and NOT 159mm as listed above. Hope someone finds this helpful.
I realize this is an old thread, but I have a chance to get some handles for my AU-717, and I need to know the exact size so that I don’t buy the wrong ones. In the various posts above where it mentions 168 mm as the height, is that measurement the height of the entire handle (from top to bottom, as it were, when mounted on the amp), or is that a measurement between the mounting hole centers? Can someone please clarify that for me?
Mine measure real close to 140mm total height and 100mm bolt CtoC.
Interesting. The lists above put the 717s at 168mm “height.”
AI Overview
The Sansui AU-717 amplifier handles measure 4 inches center-to-center on the mounting holes and are 5.5 inches tall overall. These are original rack handles designed for the AU-717 and other Sansui models like the TU-717, 719, 517, 519, 417, 919, SC-2110, and 3110.
I’m wondering now where the various measurements are made. Is the height measured on the plate that has the mounting holes in it? Or is it measured at the base of the handles where it flares out to a wider point. Does anyone know? Is it A or B in the attached photo?
You left off the most critical dimension center to center on the holes.
Well, you’re probably right, and that could be added. I assumed that the dimensions mentioned above were in reference to the physical dimensions of the handle rather than the distance between the holes. I have a handleless 717 set that’s packed away at the moment making a measurement a bit of a pain. Hence my question.
For a TU 717, its 6-1/4 and 5-7/16 near as I can measure with the access I have. I can't get a cean measure of the CL to CL on the holes.
