SansuiHafler
I have two identical Hafler power amps except that one has larger power supply caps (64,000mfd vs 40,000). Should the supply rail voltage be different assuming it’s tested using the same audio input and output load conditions? Should one amp voltage dip down more than the other? Trying to understand my VOM readings. I do not have a scope.
