When purchasing parts in bulk it is hard for an OEM to say no to a fantastic deal even if it is marginal to the specifications as in bare minimum or even under what is ideal. The same thing is true in reverse it never hurts to exceed specifications with power filter caps assuming they fit in the space allowed and it is even better if they get a great deal on them!
i say this all the time this is why my fantastic and I love to death Carver brand amp ended up with power filter caps that are are rated 7 to 10 volts under under what is actual on the rails ended up in the amp! Just like when you pop the hood on a a big V8 engined car or truck and find a battery that is far smaller than ideal because the OEM got a fantastic deal! It is going to make it out of warranty no problem with no failures and will work just fine meeting the specifications of the unit which normaly have plenty of wiggle room built in well in the past at least.
Every company does this especially if the end consumer can not easily see that corners have been cut. Traditionaly capacitors, switches, pot's, power cords, bulbs where the places cost cutting showed up first.
