No sir, still sitting in the pile patiently. The good news is that I have almost completely stopped buying gear, so they are actually getting closer to the top of the list, lol.
Great-looking speakers - and you're right about there being little info on the web... How old are they? They are somewhat different from most classic German speakers in that they are 8 ohm and don't have rounded cabinet corners. Is the crossover on the back panel? Great-looking setup, by the way...
It was a way to mark the foil. One lead would be connected to the outer layer, the other the inner. Its non polar.Based on the serial numbers, my guess is they were probably built in 1969 and were the 6th (69006) and 10th (69010) made. There is a single capacitor to the identical tweeters as shown in the photos and diagrammed below. The woofer appears to run wide open and rolls off naturally.
By the way, ignore the polarity markings in the diagram. The original caps had markings suggesting they had polarity, but the consensus here was that they were not polarized.
A few more to offer.Ok, the Burhoe Blue are gone; had some Reds for a while as well.
Residing right now? Currently listening to a pair of Mirage SM-1, pre-API ownership, and pre-350/450/650/750 as well. The SM-1 speakers are hitting all the right notes. Incredible speakers, with a Philips tweeter surrounded by a felt ring. Loving them.
A/B'ing with the Mirage? A pair of excellent Audiotronix GL 300 bookshelfs, from Glenn Electronics, Oakville, Ontario, Canada. Excellent sound, apparently morphed to MiTronics Then Lazer, then BSM.
Lurking and waiting for love: LEAK 3050, no covers but going to look great without them. Waiting for surrounds. Micro Acoustics, possibly FRM-3, with the lollipop physically tuneable tweeter. Waiting on surrounds. EPI 80 bookshelfs, waiting on surrounds. Design Acoustics PS-66 bookshelfs, acquired at some point by AudioTechnica, waiting on surrounds.
In and out of the rotation depending on what I am feeling musically: Mirage 750, Energy PRO 22, Telefunken Compact 30.
Sleepers in the background? KEW 5, large front speakers totally similar to JBL L40, but featuring a 12" rear-firing passive radiator. 12" CTS or Gefco woofer, what appears to be a Motorola piezo tweeter, and they sound just so good! Apparently built originally on a Dayton/Wright licence, but variance from the design and specs saw the licence pulled. Never-the-less, an incredible sounding speaker that saw my JBL L40 speakers on their way to Montreal, and the KEW 5 still here.
Been a few other rare speakers through here, including RTR EXP-8 (exceptional), really early Paradigm (Model 7), and the crowning glory: Crown, possibly made by RTR, with a four-element per speaker array of JanZen electrostatic tweeters.
Always looking for the weird and accessible speakers.
There is a lot of debate on whether it really makes a difference in how they are installed. Many non polar caps aren't even marked anymore. Yes, you may see a slight difference on a scope, etc., but I dought you would hear a difference in most if not all applications.Mr. Carlson’s Lab has an excellent explanation of the orientation of capacitor foil:
Found this in an attic, don't know how good or rare View attachment 2144560 View attachment 2144561 View attachment 2144563 it is.
Yes, they are identical, not mirror imaged like some of their other speakers.Is the pair like that? Green Mountain Audio does some unusual shapes....
I have the L300/8s (Woofer with a coaxially mounted tweeter and a mid on top). Woofers were fine but needed a refoam job from Richard. They sound insane for their size. Picked up from some old Russian dude in Brooklyn.Braun L200, drivers rebuilt by Richard So, all caps replaced with Jantzen polypropylene, and replaced internal wires.
Camera is a not too common Leicaflex Standard.
German technology at it's best.
GNP audio System 220.
I really didn't know what they were called when I bought them.
I found a reference to them here from last year.
They were 16 ohm and preferred my tube amp over SS.
not rare, nor seldom seen.Compared to most of your guy's entries, these are worth little monetarily. But I do believe they're pretty rare in the U.S. (I was able to find a couple sold listings for sale from $50 or so, but not much info about them), and practically nonexistent in Europe considering their size.
They're 1987-88 Sanyo SSV16 4-Way Floorstanding Speakers with 15" woofers.
Drivers & Cabinet:
Super tweeter is actually a real (mylar) tweeter.
5" Midrange driver has the newer Sanyo logo on it, and also says made in Korea.
Cabinet is actually just over ¾" thick.View attachment 2125467
There's not much inside, with hardly any insulation, corner bracing, and a tiny low-mid-high pass filter.
However, these do have some sentimental value as these were my first pair of speakers that I actually used.
Some real Cabinet bracing, proper insulating material, and a proper crossover network should suffice. Only then would they sound truly decent.
I also have their smaller brother, the SSV6/7-150, 3-way with a 12" ribbed woofer. Not as rare but, someday...someday I'll stack 'em.
Currently, that pair resides in the living room downstairs.
I need to get my 1002/8s done. I just did the cabinets. Same with my Output C/4sLove your L300/8 speakers! I also have the Compact C and the 1002/8 speakers, just had the woofers rebuilt by Richard. I will post photos shortly.
