That 820uf capacitor is the main power supply filter. You could replace it say with 1000uf, paralleling it won't really achieve anything useful.
Why not start by checking the power supply voltage - measure the voltage between terminals 7 and 8 of the power supply board. And make sure it stays constant while the turntable is running.
I would say the next step is taking some voltage measurements to try and locate the problem - the caps were obviously bad but you could still have a bad transistor or even just a worn motor bearing.
Will do with the voltage check.
I figured it was the power supply cap. Paralleling it with another 820 uF would double the value of the combined caps to 1640 uF, right?
No worn motor bearings here, I don't believe. This is the quietest table I've ever owned, fwiw.
I don't keep an archive any more, since I've been out of the service business for many years, but I'm sure some folks would be thankful if you placed this information in the AK database.BinaryMike, or anyone, PM me if you would like a full-resolution copy.
Welcome to AK!Thank you all for these posts. I have the same turntable with similar issues, down to the sooty bulbs. I will update with posts as I can. I will use it as a recipe.
It is in line behind a Sony psx-70 with swollen PSU Caps,(it runs fine but smelled bad), and of course The Mother inlaw visit. Nothing happens fast around here.
Charc.
You probably have already done this, but be sure and deoxit VR1.
The plastic cap should pop off making it easier to spray, if it is the
variety I am thinking about.
See circled in pic.View attachment 1220497
