I think if that driver requires a 44'' port, you might try to figure out how to do it.
if the port can be cut in half, then cut another hole for the other section of pipe.
there are many home subs with multiple ports, sometimes it has to be done to reach the specs the driver calls for.
Under powering, and porting a box wrong can cause damage to a sub.
you may be better off sealing the port off completely, thats if there is enough cft of air for the driver.
cablephil,
i have looked at some converter charts, but cant seem to understand them.
can you tell me what the cubic foot is on a 14x14x15 3/4 inch box? im not sure the port size, i'll check in the morning. its a down firing port, i'd rather not have to move it.
I may replace the drivers in my subs after the new year, but im not sure the cubic feet of my box's.
