Re-foaming woofer advice
rwh63
i'm going to be receiving by mail a pair of 12" Cerwin Vega L121-4 woofers (along with other speaker parts). i wanted to return my speakers (CV-3000) to their original state. the woofers will need re-foaming. never done this before. wondering if folks here can offer guidance/tips/tutorial links that will assist me in doing this right. plus, the best materials to use. thx!
Best advice I read when doing my Column II's was to glue one edge (I chose the coil edge) first and let it dry completely. Then do the other edge (in my case it was the outer edge). All I did was make sure the coil would move in/out by hand once I had the outer edge all clamped up. I found it a lot easier than expected and the speakers sound like new once again. Doing them gave me the confidence to do the CS3008's too.
I usually do it in that order as well, but also hook up a 9V battery to the terminals which centers the voice coil when gluing the surround to the basket. Use a blow dryer or heat gun on low to allow the glue to dry more quickly to avoid the chance of the coil slipping out of alignment when the glue is drying.
I re-foamed my first speaker a few weeks ago. Prepping is the tedious part and take the most time. I watched this video from the re-foam kit supplier...
I used my Variac on it's lowest setting to center the cone instead of an app on my iphone as it shows in the video. But It really was surprisingly easy!
You should get the glue as a kit with the new surrounds.
Just go slow and take your time.
Lots of good advise here.
i guess i mean, is there good/better/best when it comes to these things. i see kits on ebay. do manufacturers put out kits?
Not quite sure, but that's where I got mine and did my first pair of EPI 100's woofers.
Ebay
Maybe an expert will chime in and set me straight, but as far as I know speaker mfgs (like Infinity for example) don't make re-foam kits. Furthermore, I suspect the foam surrounds are all made by one or maybe two manufacturers.
The company I chose to purchase from was largely based on the information I saw on their web site, along with the "how to" videos they provided. As far as the foam surrounds themselves, I doubt there's any difference from one vendor to the next.
looneytune2001 on ebay sells good heavy foam kits with the glue, instructions, and CD with the tone on it.
You want the
Cerwin Vega AT12,ATW12,SUB120, VS120 12" Foam Surround Speaker Woofer Repair Kit
Ok kids, the pieces arrived in good shape today. Here are some pics. Let me know what you see.
As a back up, what be the expected cost to outsource?
That's an excellent video that is embedded above. He is a little more cavalier with his handling of the cone than I was with mine. I 'dry' scraped the old foam off the cone as I wouldn't risk getting them wet even with IPA since they aren't available any longer. Getting the gaskets off mine was the hardest part of the job as others have noted on the Infinity forum here. All in all it's a very rewarding experience to do it yourself. Let us know how it turns out.
