Re-veneered Pioneer PL-518
Thats looks fantastic. Great job!
I have been thinking about doing this for a while to a Pl-518/540 or 560. Which ever one falls into my lap first. The only thing keeping me from doing it was the fact I didnt know how difficult it would be to remove the base right around the tone arm and assemble it back again. Was it very difficult?
Thanks for the logo... I might try and brand it on. A clear decal is more reversible, but over time the covered area will fade in color so pulling it off won't be an attractive option.
For anyone thinking about doing this to a Pl-518 (I can't speak for any other TT):
Disassembling the unit is very easy, and re-assembling is even easier. The only thing you have to have that you might not already own is a hex-key set. The screws that keep the tone-arm assembly in place require hex-keys to remove. Get a decent one from home-depot that has like 20 hex-keys, and the four hex-screws will come out with ease.
The plinth is just a big wooden donut, and the tone-arm assembly passes through this hole very easily. Rest the tone-arm assembly on the bare metal chassis, using one of the rubber feet as a spacer. Leave that whole thing in a safe place and just turn all attention to the ugly plinth.
The vinyl covering on the plinth comes off very easy. Start at a corner with a finger nail to get a start, then heat a small portion from that corner with a very hot iron and the just peel. You could use a wood chisel to help with this step but I found my hands to be all the tool I needed for this step. The sides come off leaving a little glue residue, which you can attack later with the iron, a wood chisel to scrape up that tacky gunk, and then sandpaper to chafe and smooth it in preparation for gluing.
The top veneer is very thin and comes off easier than a sticker on glass.
Use a veneer kit to make the sides and the top. The top is a little tricky because of the holes, but the PL-518 is designed to make your life easy. The platter and the tone-arm assembly will extend over the attachment area, so you don't need a perfect cut on the veneer. The edge imperfection with respect to the inner plinth hole will be covered up entirely by the platter and assembly, so don't worry too much.
Attach the sides first. Use contact cement. The contact cement is applied generously on both the veneer and the plinth, then allowed to dry. At this point the contact cement will not stick to anything except another surface that's covered in contact cement -- and when that happens, it is absolutely permanent. So cover the plinth side with a piece of wax paper, align the veneer (over-cut it by about a half-inch in each dimension), and then slowly pull the wax paper away and use the back of a wooden discwasher or other rounded wooden implement to apply pressure to the small exposed area. Slowly work your way down the entire side. Let the two surfaces bond for 15 minutes or so, then sand off the excess areas (carefully and slowly) with a medium-grit sandpaper.
Do this to all sides and you've got a reveneered plinth. Finish according to the wood that you've chosen -- for cherry, I used just a lightly application of teak oil. Re-assembly is a piece of cake. Test a record or two -- the auto-return might need 1 or 2 tries before the gears are properly re-calibrated to their intended positions, but re-assembly will not require you to worry about gear positions or anything like that.
Very nice job! :yes: :thmbsp:
If the clear decal idea doesn't work out for you, you may be able to
try a metal speaker badge just to get the Pioneer logo on it. :scratch2:
Scott
Beautiful. Leave the Pioneer logo off and make one that says ; fivealive. Fitting I think.
cubdog
It looks very good, nice job! But I have to say your 518 was, as you said yourself, not the prettiest TT around. I own the 518-X, which looks better in black:
But still, when I've finished some other projects, I might treat my Pioneer...
The black looks good because the color holds up over time. That aircraft carrier grey (as someone called it earlier) might have looked fine when new, but it started to discolor and skew towards a rusty brown, which was just nasty.
