ROLL CALL!!!
Hi all, I'm new here. I've been active in the past on other forums (car based stuff) but I've been lurking here for some months. Like many of you, I saw and drooled all over Mach speakers at the local Radio Shacks, while playing with the remote control cars while my dad was buying serious stuff (resistors, bread boards, pots, and the like). I remember looking at the Radio Shack catalog, and seeing the giant Mach II speakers. It had the same appeal that adult magazines had... wow. Anyway, I digress.
Fast forward 3 decades, three houses, and two children later, and here I am at a local recurring junk sale poking through the newest batch of garbage hauled in from the scourges of the last bits of an auction... They always have really obscure things there - a chainsaw with no case, chain, twisted bar... a pile of terrible records, with ONE gem in the bunch (Jackson 5 stuff) BUT NO RECORD in the sleeve. A chandelier missing one globe... And now this time a pile of 1970s and 1980s speakers. A pair of Cerwin Vega's with one of the woofers replaced with a generic sits there with a sold tag... but behind that, looking abandoned and forlorn, is a big beefy real wood box, and its twin behind that.... yup, Mach IIs. $40, and they were mine. I didn't even hesitate and look at the condition, I wanted them. It was like meeting a centerfold.
Brought them home to find they have the typical foam rot on the woofers, but the cones are in good shape, dust caps not dented or damaged, and the spiders held the cones in place. With gentle even pressure, they had no rubbing. The mids were just showing cracking in the surrounds behind the grills. The L-pads felt smooth. The cabinets had seen some water at some point - I'm sure they were in someone's basement - the bottom corners were just swollen, and the big speaker grills had some wicking marks in the cloth. The drivers show no water damage at all, and the cabinets are solid otherwise.
Hooked them up and gently increased the volume. No scratching or rubbing, but didn't drive them long. Just ran them long enough to find that one tweeter didn't make any sound, but all the others were ok. I opened the cabinets to find that they were clean on the inside, no infestations, no water damage on the inside to speak of (sure, the moisture from the outside corners I know is there, but you couldn't see it on the inside). The light bulbs were all in tact, and no obvious damage to be found on the crossovers. I'm assuming the tweeter died from a crossover cap going bad possibly. I knew that old crossovers often need re-capping, so I started searching. I found this thread.
I will post up pictures in the coming days, but I just wanted to see who was still reading this. I have decided I'm going to follow the re-capping and re-coiling process done by RickyM, and I'm going to use the Realistic Mids 40-1281(a) to keep the speakers all "Realistic" and less Frankenspeaker. Maybe Copa and/or Ricky have some long term feedback? I can't wait to re-foam my woofers and bring this big pair of knockers back to the home theater.
