I just picked up a pair of Mach 1's--the 4029 version and the woofers were all rusty, moldy and contained no foam surround because it had deteriorated. When I pulled out the woofer the back said 6ohm on both. I thought the 4024's were 8ohm and the 4029's were 4 ohm??
I plan on getting two new woofers from PE.
Finally, what can i use to replace the stinky, moldy yellow insulation that was in each speaker? Thanks again!
