audiozaz
rtfm!? - tl;dr
So I picked these up at goodwill earlier this week, 3$ for the pair, could not pass that up. I got a thing for small speakers, especially Realistic... 5.75" high, 4" large, 2.75" deep (internal dimensions) 1/2" particle board, veneered, acoustic suspension design. Plastic faceplate with fullrange 4" driver in the center. A little wad of fiberglass wool in the box. 10W max, 8ohm. Cannot find any info on the internet on them except on TAC, which stated manufacture date from 1993-????
It's not like I was expecting these to sound great, but I was quite disapointed when I plugged them in and gave them a go... They sound like music through a telephone. I EQ'ed them to check, and 64Hz is barely usable, as in the ±12dB slider's absolute difference of 24dB is barely heard. I know the limitations of a single 4" driver, but I've heard them do better.
I would like to do some cheap mods to help them sound just slightly more decent if possible. Here is what I had in mind, feel free to improve or comment on that.
1. Find driver's Fs and put in a low-cut filter something like 1 octave below it to avoid uncontrolled cone motions for frequencies at which it cannot respond properly. The amp is still trying to pump them to it.
2. Better acoustic isolation of the driver and wiring terminals. The speaker is screwed-on metal to plastic, while the terminal pad is plastic to wood. A little dense foam cut-out would help making the cab more airtight.
3. Dampening material. Not sure which way to go on this one, remove or add. But that's an easy one to test and re-test and re-re-test until best compromise is found.
4. I would like to do something to help high-frequencies, but I'm afraid nothing can be done for that.
All of this can be done withing a couple of hours and practically for free, so I don't stand to lose anything, which is kinda what I aim for, since they are not great speakers to begin with.
So is all of it pure madness or am I making some sense?
az
az
