The speaker read 4.0 ohms on my fluke.
You said the speaker reads 4 ohms. That's not right. You need to measure between the black and blue wire, with the blue disconnected from the crossover or pull the tweeter out and unhook it and measure that way. It would also be good to measure the mids between the black and white wire. Also, one of the wires should be disconnected as well. They both (tweeter & mids) should read right at 7 ohms each. If they don't we need to find out why. The mid drivers should be measured only from the black & white wire so the series is hooked together for the 7ohms reading.
I have a pair of 5b tweeters that I am willing to donate to the cause. I just disassembled a pair of 5b's. They are Model 0725Ac 8 Ohms; 350Khz to 18KHz. they are yours for a clear parts list and wiring diagram (posted here of course). PM me and I will send them off.
The speaker reads 4.0 ohms across the terminals when disconnected from the crossover. It is marked 4 ohms on the back. This is a Optimus 5B.
The mids sound ok, but I'll have to measure them (out of the cabinet) when I get home. Since the mids are in series and are 7 ohms, that should result in a 3.5 ohm load to the crossover.
First off a quote by rmeade
Then a quote from Smorgy
As I said in a post previous to this one, I didn't think you had an original tweeter. Rmeade says he has three pair and the number he has listed is the stock tweeter number and it is 8 ohms. Also, I am glad you found your loose wire on the tweeter that was keeping it from working.:yes:
Drivers in series doubles the impedance. Each of the Mids are 4 ohm units and the two in series should give you 8 ohms with a DCR of around 7 ohms. I am not sure where the 4 ohm tweeter unit came from, but again, I don't think it is an original driver based on what I have seen in the past and on rmeade's findings. That is why at the start of this thread I posted the pictures so one could see the driver numbers and impedance of each. This allows you to check that your drivers are the same that I designed the crossover for. The crossover may work ok with it but it will not perform as it would with the stock 8 ohm driver.![]()
For sure the tweeter has been swapped out, probably for a mid. I'm guessing since it is a 4ohm speaker and looks identical to the mids. It is not marked "midrange" like the others though.
I will pm rmeade and wow! what an offer, thank you! I tried in vain to find a pair of correct tweeters online.
So, here is what I have:
Woofer 8 ohms (measures 7.0 ohms) 3007Aa Japan (Cast aluminum frame with oval slits from the mounting surface to the magnet, looks a bit art deco-ish)
Midranges 4 ohms (measures 7.6 ohms in series) 0710Aa Japan marked "midrange"
Tweeter just says 4 ohms
Grills say Optimus 5B
Rear of cabinet says Optimus 5 Cat No. 40-2002
So, shame on me for not detailing my parts list ahead of time.
Somebody, at some time in the past 25 years or so, swapped out the tweeters and the grills on the ones I have.
Assuming the tweeter circuit is correct (?) then all I really need is the correct tweeters to be able to close this one up - and start on the 2nd one!
//Smorgy
..........., you could just try to find a pair of the 8b tweeters. The number is: 725ac 1D24D. Radio Shack still sales a new replacement tweeter for the Nova 8B! I will let you know what I find.:scratch2:
Did you find anything on these replacement tweeters from Radio Shack? I just spent an hour poking around their web site and didn't find these. If they are available, I would definately buy a pair.
//Smorgy
//Smorgy
I got on part express and found a P-core 2.7mh part # 255-110. Us it in place of the 2.7mh part # 255-434. This will save 30.00 bucks and will perform better. It has less than half the DCR of 255-434!! You can save another 4.00 by using part # 266-554 for the 18ga 2.0mh!
I'm waiting on a pair of correct tweeters from RMEADE. (Thanks!!)
Anyone have any luck ordering the Nova 8B tweeters from Radio Shack?
Are all of the "B" tweeters the same? (1B, 2B, etc)
//Smorgy
Is it possible to enter 4ohms into the tweeter crossover cap model and end up with (for the most part) the same sound?
