The woofers run full range in these. A lot of 2way RS speakers are made this way. They let the woofer roll off naturally.I am no expert but is it possible the inductor and capacitor are reversed?
The schematic in post #2 is a series circuit found by @nerdorama in an Optimus-1 having drivers with ceramic magnets. He had another Optimus-1 with all alnico magnets that had a parallel crossover circuit. Its capacitor was 30µF rather than 33µF. Both of these were model 40-1969A, so neither being the very earliest version (40-1969).I am no expert but is it possible the inductor and capacitor are reversed?
I would wait until you can test the speakers, as those tweeters are notorious for failing. I convert the Opti-1 to a 3-way and sell the working tweeters.I have some Optimus 1 speakers coming to me soon I plan on recapping them does anybody know what capacitors I need so I can have them when they arrive?
Magnet shift can be a problem also. Like Polk speakers, the glue didn't hold up well over the years.I would wait until you can test the speakers, as those tweeters are notorious for failing. I convert the Opti-1 to a 3-way and sell the working tweeters.
I've yet to see an instance where adding the coil to the woofer doesn't improve the sound. Adding a high quality bypass cap on the tweeter works too. I have a bag of Blonder Tongue low cost .01uf bypass caps that are perfect for speakers like these.Magnet shift can be a problem also. Like Polk speakers, the glue didn't hold up well over the years.
I took a pair of Nova 7B's, same as the Optimus 1B, and rebuilt the crossovers per what another AK'r did. It made a very noticable change for the better by adding a coil to the woofer, and a bypass cap across the woofer. Anyone with a pair of 1B's or 7B's it's cheap, and worth trying.
Also very easy to put back stock. I also made new grills for the 7B's.
I just can't abide those plastic lattice grills.![]()
Ya, getting the woofer to stop stepping all over the midrange really made a difference. These 2ways use midrange/tweeters.I've yet to see an instance where adding the coil to the woofer doesn't improve the sound. Adding a high quality bypass cap on the tweeter works too. I have a bag of Blonder Tongue low cost .01uf bypass caps that are perfect for speakers like these.
Do you have a small orbital sander? I've come across and have some speakers where tye veneer was scratched up pretty badly and even water stains. I used 120 grit if they had a clear coat, then finished up with 150 grit.Thank you all for your replies. I got them they sound great the grills woofers and tweeters seemed untouched but the veneer is trash .The seller hid allot of issues. I'm trying to decide if it's worth a full restore or cut my loss .I paid 25 bucks so it's not too bad
Hey, I am new to the forum. I have a set of optimus 1 and was going to recap to a Solen 33uf. The crossover coil discussion has me interested while I am in there. Looking at a Dayton 1.5mH 18 AWG but could you explain a little more about the process and the bypass cap across the woofer?Ya, getting the woofer to stop stepping all over the midrange really made a difference. These 2ways use midrange/tweeters.
The designer of Realistic speakers posted here on AK a few years back.
He designed speakers from the late 60's through the early 90's if I remember right before leaving because of how marketing kind of took over and wanted more cost cutting.
He stated they had the woofers designed to roll off where they wanted them to. He seemed to be from the less is more crowd when it came to crossover designs. I'm sure price points had to be factored in also.
The Nova 6's and up and the Optimus 2B's and up in the 70's weren't bad sounding, but they can be made to sound better. I'm still looking for a pair of Nova 8B's or Optimus 5B's locally to try the VL crossover mod on.
