Realistic Optimus 1b Tweeter Help
nthagarage2
Needing to replace a Realistic Optimus 1b pair of tweeters. I’ve looked on Enay and so far none match the markings on mine 0705Ae 16 ohm. Any suggestions on replacements other than holding out to find originals?
View attachment 2144624 View attachment 2144623
I know this is an old thread but do hope that you see my reply!
I’m in the same boat as you; were you able to find replacements? According to ChatGPT, any 7505 variants will work. I can see the variants except the 7505Ae. I love the sound of the speaker that is working and would like to find original tweeters instead of aftermarket. If I don’t find the Ae version, I might get two 7505s, take a chance and split the drivers across cabinets so each has one 7505 and one 7505Ae. Thank you!
FYI - The Nova 7B uses the same 16 ohm tweeter.
Yup, same speaker except for cosmetics of the cabinet.
I have a pair of Nova 7B's I made new grills for. I'm not a fan of the lattice grills.
I also modified the crossovers per what another AK'r did. It's similar to the VL mod for the 8B's.
I added a 1h coil to the woofer to fo e it to roll off where it should.
A bypass cap across the woofer, replaced the old electrolytic cap with a film cap and reversed the phase of the tweeters.
This mod does add better control of the bass.
Other variants are 4 ohm and 8 ohm. They would fit physically, but wouldn't perform the same. Crossover point would likely change, but who knows by how much. Unless you want to model the changes to the crossover point and redesign the crossover, I wouldn't go that route.
Yes, I’ve found options for the 7B which have the same tweeter so that’s what I will go with. Thank you!
