Just take it slow and easy. There are a lot of screws holding this thing together and a lot of disassembly of the chassis. Take lots of pictures as you go. And be mindful of capacitor orientation. Some of the + and - marks printed on the boards may be backwards. Make a make with a sharpie on the board to mark the negitive side before replacing any.Thanks to @Lavane and @creig elder for posting this schematic. I just picked on up to refurbish, and this was a great help to get me started
Thank you for your reply. I'm sorry that I gave the impression that reinstalling the board might be the cause of the issue. It happens intermittently whether the board is secured or not. It seems to just have something to do with the state of the capacitors and transistors on the PS/Protection board because it will sometimes click in and sometimes not. I really don't think it is a faulty relay. I might be found wrong on that. I have all new electrolytics caps and new transistors coming tomorrow. My plan is to remove them one by one and replace all of them. There are only half dozen cans and half dozen transistors on that board. I'll be labeling all of the parts as I remove them with their locations and I'll be marking the board with the orientation of the caps ass I remove them. I have a semiconductor testor to check the pinouts of the transistors as they are removed to make sure the replacements are the same before installing. Hopefully it all goes well, I want to fix the issue before I more forward with recapping the whole unit. Any suggestions or guidance are apprecaited.If it stops when you unsecure the power supply board and goes into protection and you screw it back down I would be looking for a short. Maybe a wire, or a blob of solder close to the edge of the board grounds out to the chassis when the board is screwed down? Really loom over the under side the board. It's been awhile since I've been inside my SA-2001, but if you can get a good look at the underside of the board with the bottom of the chassis removed, look for anything that could be causing a short to the chassis.
We're any of the original small electrolytic caps on the power supply bloated, or discolored on they're side! Two of mine were. There's a dropping resistor that can get pretty warm, and so can the voltage regulator. I bent the resistor away as far as I could from the new cap next to it and also added a small heating to the voltage regulator. I used 105° caps on the power supply board when I replaced them too.Thank you for your reply. I'm sorry that I gave the impression that reinstalling the board might be the cause of the issue. It happens intermittently whether the board is secured or not. It seems to just have something to do with the state of the capacitors and transistors on the PS/Protection board because it will sometimes click in and sometimes not. I really don't think it is a faulty relay. I might be found wrong on that. I have all new electrolytics caps and new transistors coming tomorrow. My plan is to remove them one by one and replace all of them. There are only half dozen cans and half dozen transistors on that board. I'll be labeling all of the parts as I remove them with their locations and I'll be marking the board with the orientation of the caps ass I remove them. I have a semiconductor testor to check the pinouts of the transistors as they are removed to make sure the replacements are the same before installing. Hopefully it all goes well, I want to fix the issue before I more forward with recapping the whole unit. Any suggestions or guidance are apprecaited.
Thanks for the follow up. I may have to dig into mine deeper as well.I recapped the power supply and the protection circuit and amp board, and the amp is back working properly again. Eventually I'll need to do the phono board and the preamp but that can wait for now because it is all working fine
