Realistic STA-111 anybody know this one?
30 wpc. Introduced in 1981. Advertised as "System Eleven ... equalized for enhanced bass from mini-speakers." Seems to have been targeted for use with Minimus speakers, much like the STA-7 ("System Seven") did a few years earlier.
It made the cover of the 1982 catalog with full info on page 7:
http://www.radioshackcatalogs.com/catalogs/1982/
Know where I can get mine fixed?
I bought one from an out of state Goodwill through Ebay. Only problem is the FM Stereo is messed up. I tried a local shop but they declined to work on it because of the digital tuner. The amp section appears to be OK. Any recommendations?
There is a sticky on AK on how to clean tuners. If that don't work you might want to send a PM to AK member Punker X. He works on tuners and he might help you out.
It looks like the connectors are on the far left, looking at the back.
They are the black plastic nuts, 3 in a row.
Try using the right-most 2 of the 3.
Note that I am assuming that you are using a dipole antenna, a flat wire with 2 leads.
If you are using coaxial wire (like the cable connector) then you use the 75-ohm connector to the right of the 3 black plastic nuts.
