Brivan
Well-Known Member
Good afternoon,
I've been battling a perplexing issue with the amplifier board for the right channel of a Realistic STA-2080. The entire receiver is great shape, with no heavy wear evident. The amplifier boards are no exception - all components appear as new.
As I usually do with these receivers, I replaced both idle current adjustment pots with Amphenol single-turn 200-ohm pots. I do this prior to power-up, since there are so many of these receivers that have flaky idle current pots, resulting in destroyed components on power-up (if they haven't been damaged already)
The left channel was easily adjustable for 10mV at R509, but the right channel would quickly jump from around 3mV to around 40mV or 50mV as the pot was turned clockwise. I've measured the pot (checked fine) and even replaced it - to no avail. After this, I replaced TR506 & TR507, per my notes. This made no difference. Long story short, I've replaced all the transistors, pulled one leg on each of the resistors and checked their values, temporarily replaced D501, 502 & 503 with 1N4148 diodes (in series, where needed). D506 was replaced with a SB140 Schottky. D504 & 505 were tested okay. All electrolytic capacitors were replaced. Output transistors were tested. Power supply voltages all checked good.
My list of replacement transistors:
TR505 = KSA1381
TR504 & TR506 = KSC3503
TR507 = KSC2073
TR508 = KSA940
TR501, TR502, TR503 & TR511 = KSA992 (TR501 & 502 gain-matched)
I have a spare STA-2080, so I pulled the right-hand amp board from it and tested it in my problem receiver - it worked fine. I installed my problem right-hand amp board in the known good receiver and it exhibited the same jump in voltage measurement across R509 that was witnessed in the receiver it came from. This eliminates anything outside the amp board as the problem, but I'm at a total loss as to what else to check. I've examined traces, solder points under a magnifying glass and they all look fine.
I've read other threads on this subject - some with a definitive solution and others - like mine where every component was seeming replaced / tested - remain unsolved.
Any help I can get on this would be appreciated!
TR505 = KSA1381
TR507 = KSC2073
TR508 = KSA940
