Nicholas M
Hey all,
Recently acquired a very nice set of AR4xs. Pots are pretty dirty so I am going to try and clean/restore before I go a different route. Back to that later.
I do want to update the caps on the crossover. Here is the photo of it presently configured:
Here is are my serial numbers so XO style can be traced. I'm also wanted to resolder new leads from the tweeter to the cross over because I had to snip them to test the ohm. What's the gauge of those leads so I can find colour matching ones?
FX 39899
Tweeter ohm rating (out of cabinet): 4.8
Woofer ohm rating (out of cabinet): 5.3
FX 43162
Woofer ohm rating (out of cabinet): 5.7
My very hobbyist level of understanding tells me that I need 2x20uf 250v crossover caps. My question is how to solder them into the current unit, which leads are removed, etc.
Any help and direction would be greatly appreciated. Also, in the instance of the pots not being saved, may I put in a resistor with an L pad or without? What ohm rating, and how does that can configured?
thanks!!
FX 39899
FX 43162
thanks!!
