Note: don't use the below recap list yet as it is under development, not finalized.
I have two HK 330B stereo receivers, the "Roland" model, that I'm planning to recap and restore. Here are the components I'm planning to replace along with the parts from Mouser.
Your comments and corrections are welcome....
Board Component no. Type Sub-type Value Rating 1 Mfg Mouser PN Value Rating 1
AM Tuner C268 Capacitor Electrolytic 220 uF 6.3 VDC Nichicon 647-UPW1A221MED 220 uF 10 VDC
AM Tuner C272 Capacitor Electrolytic 220 uF 16 VDC Nichicon 647-UKL1E221KPD 220 uF 25 VDC
Control Amp C501,C502 Capacitor Electrolytic 1 uF 25 VDC Nichicon 647-UKL1H010MDDANA 1 uF 50 VDC
Control Amp C503-C506,C521,C522, Caxial Capacitor Electrolytic 1 uF 50 VDC Nichicon 647-UKL2A010KDD 1 uF 100 VDC
Control Amp C507,C508,C523,C524 Capacitor Electrolytic 10 uF 16 VDC Nichicon 647-UKL1E100KDDANA 10 uF 25 VDC
Control Amp C519,C520 Capacitor Electrolytic 220 uF 16 VDC Nichicon 647-UKL1E221KPD 220 uF 25 VDC
Control Amp Q501-Q506 Transistor BJT 2SC458 Fairchild 512-KSC1845FTA KSC1845F
FM IF Amp C218 Capacitor Electrolytic 10 uF 16 VDC Nichicon 647-UPW1E100MDD 10 uF 25 VDC
FM IF Amp C219 Capacitor Electrolytic 220 uF 16 VDC Nichicon 647-UPW1E221MPD 220 uF 25 VDC
FM MPX (not marked) Capacitor Electrolytic 1 uF 50 VDC Nichicon 647-UPW2A010MDD 1 uF 100 VDC
FM MPX C301,C302 Capacitor Electrolytic 0.47 uF 50 VDC Nichicon 647-UKL2AR47KDD 0.47 uF 100 VDC
FM MPX C313-C316 Capacitor Electrolytic 1 uF 50 VDC Nichicon 647-UKL2A010KDD 1 uF 100 VDC
FM MPX C325 Capacitor Electrolytic 220 uF 16 VDC Nichicon 647-UPW1E221MPD 220 uF 25 VDC
Main amp C401,C402,C407,C408 Capacitor Electrolytic 10 uF 16 VDC Nichicon 647-UKL1E100KDDANA 10 uF 25 VDC
Main amp C403,C404 Capacitor Electrolytic 220 uF 6.3 VDC Nichicon 647-UPW1E221MPD 220 uF 25 VDC
Main amp C405,C406 Capacitor Electrolytic 220 uF 16 VDC Nichicon 647-UPW1E221MPD 220 uF 25 VDC
Main amp C409,C410 Capacitor Electrolytic 47 uF 50 VDC Nichicon 647-UPW1J470MPD 47 uF 63 VDC
Main amp C417,C418 Capacitor Electrolytic 1 uF 50 VDC Nichicon 647-UPW2A010MDD 1 uF 100 VDC
Main amp C419,C420 Capacitor Electrolytic 1000 uF 35 VDC Nichicon 647-UKL1V222KHD 2200 uF 35 VDC
Main amp Q401,Q402 Transistor Pre-driver 2SC1335-D Fairchild 512-KSC3503DS KSC3503D
Main amp Q403,Q404 Transistor Driver 2SC1345-D Fairchild 512-KSC1845FTA KSC1845F
Main amp Q405,Q406 Transistor Biass 2SC458-C Fairchild 512-KSC1845FTA KSC1845F
Main amp Q407,Q408 Transistor Complement 2SC1509-Q Fairchild 512-KSC2690AYS KSC2690A
Main amp Q409,Q410 Transistor Complement 2SA777-Q Fairchild 512-KSA1220AYS KSA1220A
Main amp Q411-Q414 Transistor Output 2SC1107 ON Semi 863-MJE15030G MJE15030G
Main amp VR401,VR402 Resistor Trimpot 100K Bourns 652-3296W-1-104LF 100K 0.5 W
Main amp VR403,VR404 Resistor Trimpot 3K Bourns 652-3296W-1-472LF 4.7K 0.5 W
RIAA EQ C701,C702,C709,C710 Capacitor Electrolytic 10 uF 16 VDC Nichicon 647-UKL1E100KDDANA 10 uF 25 VDC
RIAA EQ C707,C708 Capacitor Electrolytic 33 uF 10 VDC Nichicon 647-UKL1C330KDDANA 33 uF 16 VDC
RIAA EQ C711,C712 Capacitor Electrolytic 0.33 uF 10 VDC Nichicon 647-UKL1HR33KDDANA 0.33 uF 50 VDC
RIAA EQ C717 Capacitor Electrolytic 100 uF 16 VDC Nichicon 647-UPW1E101MED 100 uF 25 VDC
RIAA EQ Q701-Q704 Transistor BJT 2SC458LG-C Fairchild 512-KSC1845FTA KSC1845F
Voltage rectifier (Main) C4,C5 Capacitor Electrolytic 1000 uF 35 VDC Nichicon 647-UPW1H182MHD 1800 uF 50 VDC
Voltage rectifier (Main) C6 Capacitor Electrolytic 2200 uF 63 VDC Nichicon 647-LKG1K472MESCBK 4700 uF 80 VDC
Voltage rectifier (Main) D2 Diode Zener EQA01-13 13 V Vishay 78-1N4743A 13 V 39 mA
Voltage rectifier (Main) D3-D6 Diode Rectifier VO3(E ) Vishay 625-UF5408-E3 1000 V 3 A
Voltage rectifier (Main) Q1 Transistor Voltage regulator 2SC1212A ON Semi 863-2SD1815T-E 2SD1815T
Voltage rectifier (SAB) C1 Capacitor Electrolytic 1000 uF 35 VDC Nichicon 647-UPW1H182MHD 1800 uF 50 VDC
Voltage rectifier (SAB) C2 Capacitor Electrolytic 2200 uF 35 VDC Nichicon 647-UHE1H272MHD 2700 uF 50 VDC
Voltage rectifier (SAB) D1 Diode Zener EQA01-30 30 V Vishay 78-1N4751A 30 V 30 mA
