Ok, looks pretty good. One thing that I do, that's a little different, is when making connections with "hard" leads, like the diodes, just make one 90 degree turn on the end to be soldered. They really don't need to be wrapped, imo. Take 2 pair of small "wire pliers" and hold the diode lead inside of the solder lug and then bend the part outside of the lug. That keeps it from "pulling through" the solder lug when bending.
And one other thing that's just an observation is that it looks like your solder joints are a little cold. Clean your iron tip on a wet sponge, hold the tip against the lug and touch the solder between the lug and tip. Let a little bit flow into the joint and it will heat it up enough to where you can apply solder to the opposite side and get a nice smooth joint. Not a criticism, just an observation.
A ways to go but you've got a good start. :thmbsp:
Murray
