RR--
Hey everyone! long time since I've been here but I recently came into a problem depriving me of my favourite Sansui.
Back in 2013 I recapped my Sansui AU-719 with all new Nichicon, Panasonic and Gold Tune caps. I also replaced the main fuse for the Australian 240V system. Original post here: http://audiokarma.org/forums/index.php?threads/finished-recapping-my-au-719.528233/#post-6918224
Since then I've also replaced the big four capacitors. I've been listening to the amplifier nearly all day every day since then and loving it.
Recently this summer on hot days (like today) the amp is having issues coming out of protection mode when turning it on. Today it wont last more than a minute before tripping back into protection mode. If I play around with the switch after a minute I can get it to come back on but only for another short while.
I figured it was a heat issue so I replaced the thermal compound on the output transistors and adjusted the bias and DC offset again just to be sure but it's making no difference to the problem.
FYI the sound quality is fantastic for the minute before it trips into protection, no scratchy noise, crackles, pops or anything, when the protection clicks on it sounds normal.
Any ideas on how to bring back my pal? I'd really appreciate any help.
Thanks again
Thanks again
- unless..... some mistake or omission was made in the original recap - thus both channels could be affected ) - by measuring before the speaker relay as previously suggested.
