I have a set of Advent speakers I’d like to use along with the subwoofer that’s attached to the soundbar.
Could use a Boston acoustic subwoofer non wireless so I have to either buy a wireless adapter or run 20ft rca cable across my room.
I honestly think you are going to run into all sorts of timing issues if you have both the soundbar and the AVR decoding Dolby Digital (never hurts to try, but I have the feeling they would be out of sync with each other). It's also a very small soundbar (from your pic), so you're not going to get much sense of left/right/center/surround.
I think a better approach would simply be to use your soundbar as a center channel, and use the Advents as Left and Right (for a 3.1 setup). It looks like the soundbar has an RCA input, so you could drive that with the center preamp out of your AVR (setting the soundbar to stereo). Then the soundbar would drive its wireless sub as a "large" center, the AVR would power left/right, and you could drive your wired Boston Acoustics wired active sub from the AVR sub output. Set the center to "large" in the AVR speaker setup to take advantage of the soundbar sub, and set the surround channels to "off" so that surround effects are routed to the left/right/center speakers. I think that setup will be better (true left/right/center) and much more likely to be in sync since shouldn't be much latency for stereo through the soundbar (even then you could compensate a bit with center "distance" settings in the AVR).
I suspect your AVR does not have have preamp outs, then you'd need a high-level to line level converter (to convert Center speaker out to line-level RCA) and you'd need a splitter cable to feed that center to both left and right soundbar RCA inputs (high-level/line-level converters and splitter cables are very cheap on Amazon).
One problem you may run into with the AVR is that some content from Roku (for example) is now encapsulated in Dolby Digital Plus (7.1) even though the content is only 5.1 -- for that DD+ content your older AVR may revert to stereo rather than DD.
Personally, i think you'll be better off using those Advents along with that BA subwoofer and keep the soundbar on the TV, which it was designed for.
Once a sub is dialed into your system you don't need to adjust it again until you move it.
along those lines, here's some options. this is what I use
https://www.amazon.com/Mediabridge-ULTRA-Subwoofer-Cable-Feet/dp/B003FVX9FO/ref=sr_1_3?crid=9B14B8JY1K6Y&dchild=1&keywords=rca+audio+subwoofer+cable+-+25+feet&qid=1628517255&s=electronics&sprefix=25'subwoofer,aps,207&sr=1-3
if you truly want/need wireless, there's always this.. this is the least expensive one I found. there are others out there.
https://www.amazon.com/Wireless-Transmitter-Receiver-Subwoofers-Surround/dp/B00SJ49ZJQ/ref=sr_1_8?crid=1RQ7HBUNS57NJ&dchild=1&keywords=wireless+subwoofer+transmitter/receiver&qid=1628517417&s=electronics&sprefix=wireless+subwoofer,electronics,185&sr=1-8
Yeah thinking your right Skipper just bite the bullet, go wireless and keep the soundbar and receiver separate. Think this will ultimately be the correct method.
Until I buy the wireless adapters will try peterp1's center channel hookup advice to see what it does.
Be interesting if it did work I would have (2) subs one near my tv (Boston) and the soundbar sub in back.
Will try this this evening and report my findings.
Here's an update....................
Hooked up the Optical TV Output to Optical D-TV/CBL Input
Hooked up the Optical MD/CD-R Output to Optical TV Input on Soundbar
The soundbar volume does not raise with receiver volume and Soundbar volume does not use effects of receiver. I also do not hear latency between the 2.
Perhaps the MD/CD-R Output is a preamp channel?
If I proceed with hooking both up this would be ideal since I can control the 2 volumes separately.
My receiver sounds super echo'ee when I have different surround sounds on, believe it's matter of tweaking settings.
Had to buy a remote to gain access to more of these surround and volume adjustments so need to read and fine tune.
