I have a Linn LP12 from 1982-3. With Valhala power supply. Recapped along the way.. Came with Basik LVX arm.
The que damping doesn't work. And set screw for access has damaged socket. So have not attempted to remove set screw, to replenish silicone fluid. Other than this issue, arm is functional. I upgraded the tonearm cable and counterweight.
It was a just over $1k table in 2015, with damaged Grado cart.
Finally getting to the point:
What would be the preferable NEW tonearm upgrade choices? Budget maybe under $1500.
Linn arms are 211mm mounting distance. Basik LVX is 229mm length.
I looked at Origin Live site. Thier Silver model is £720 ($980). Can be special ordered in Linn length, for £250 extra. Or, buy new armboard to fit Origin arms for £27.
IMO, a big pita with this Silver arm is VTA adjustment is done from underneath! Not until thier Endeavor arm £1440 ($1980) do they offer side VTA adjustment.
Removable headshell arms seem to be out of vogue. Although to me would be handy. I realize one piece arms likely improve SQ.
New Linn Akito tonearm lists starting at $2400. Out of budget.
Thanks for reading.
OG
Thanks for reading.
OG
