Did the round gaskets come with the outlet cover or were they a separate item?
Thanks,
Doug
Hey Doug, yes the black foam "gaskets" came with the outlet covers.
I picked up everything I needed at Homeboy Depot tonight! I'll put it all together tomorrow. :yes:
Thanks for a great posting! :thmbsp:
I'm new to this forum, and I followed the instructions in this thread to clean some thrift store record finds I had which tended to play rather fuzzily, theoretically due to dirt that I couldn't see, inside the grooves. So, I made up a bowl of warm water with some Dawn in it, got a new, clean paintbrush, swabbed each side of the record twice, rinsing in between, and dried them with a microfiber towel. I did notice that I do not have the terrycloth-like towel, but rather the regular flat one. Anyway, I've now done this twice to a few of these records, but still for some reason I get a large accumulation of dirt on my needle everytime I play them. They start out relatively clean, but there's constant pops and noise, and by the time I get about one track into the record, it's staticky/fuzzy sounding, and if I stop it and look at the needle, it's got a large ball of white fuzz on it! I'm really at a loss for what I'm doing wrong now. I've had this problem for a long time. It seems like the only records that play nicely are the ones I got from my dad, and even some of those are no good. The needle is new, purchased just a few months ago. Can anyone help this newbie out?
Thanks,
Dan
Like most of us your finding out that unfortunately a vacuum step is needed
Thanks,
Dan
I don't know if links to other forums are tolerated here so, if not, feel free to delete this post. I won't take credit for this method, as another forum member here pointed this out to me, but it save me much $$$ and time (forget drilling holes, etc.) and is MUCH cheaper than the groovmaster:
http://www.stevehoffman.tv/forums/showthread.php?t=181384
Thanks,
Dan
Water is a universal solvent and by nature contains dissolved solids......
I feel if you use tap water to rinse your vinyl records some of the dissolved solids will remain imbeded in the grooves of the record. Is it enough to cause a problem? I cannot say with any certainy.
