WickedSharp
Scratchy and crunchy is how I like it
Your symptom is staticky sound? Do I need to remove and replace, or maybe just DeOx?
Replacement would definitely guarantee a solution if that is the reason for the problem. I say that as I haven't had much luck deoxiting the rectilinears, they still have dead spots and spots where they crackle. I think those are sealed pots, plus they are sealed by the speaker enclosure itself, so I'm thinking heat might be the issue as to how those pots begin to die, and not contamination in the traditional sense.Your symptom is staticky sound? Do I need to remove and replace, or maybe just DeOx?
Rectilinear did not use Bogen speakers in these earlier models (III, X, Xa, XI, XII, but maybe not other a,b variants).The tweeters were the Peerless, mide Phillips, and woofers varied a bit but mostly CTI or earlier Jansen.
EIA code of 589 indicates Bogen, which is kind of surprising.
