Easy cheap fix for your reel holders
I have three decks that use rubber holders, and two of them were in need of help. About ten years ago, I thought of a clever idea to try that seemed to work pretty darn good at the time. Now, all these years later, those same rubber holders are still in use with the original repair job I did years ago.
Best of all, it's cheap, easy, and quick. I did a holder just a little while ago so I could take pictures for this thread. Took me less than ten minutes to do one holder.
Get some electric tape... good quality 3M or better. For the reel holder I did earlier, I used red tape so it would show up in the photos. Get some scissors and a toothpick. Grab a cotton swab and alcohol, too.
First, clean out the hole of the holder with your cotton swab and alcohol. Dirt in there might make it difficult for the tape to stick.
Cut a piece of tape appx 1/2 inch. Fold it backwards and longways in your finger, put it in the hole, and using the toothpick, press in the middle of the tape so that the sticky side is now up against the inside of the hole. Hold it in there securely with the toothpick or it will come out when you try to let your fingers go.
A fair amount of tape will be sticking out. Trim off with scissors, leaving about 1/4 inch sticking out. Then, cut 2 or 3 slits downwards. Fold those over. Using the toothpick, kinda go over what's in the hole again. This gives you a new lining in half of the hole.
BEFORE GOING FURTHER, put your reel holder on your machine. It's very possible this is all you'll need. If you think it feels snug, leave it as such and try it for a while. If it is indeed snug, and you try to cover the other half of the hole, it will end up being too tight.
Try it that way for a while. If you feel it needs some more grab, go for it and cover the other side.
When I did this years ago, I figured the tape would end up working it's way out over time, but it didn't. As I said, it's been about 10 years since I did this and it still holds fine. Even if this fix only lasts a year, spending a few minutes to do it again isn't so bad.
Take note... the TEAC holders I worked on were the type with the hole on one side. Seems I recall this is the older style. The newer style has the hole going all the way thru may not be as easy to fix. If memory serves, the inside of the hole on the newer style has raised bumps in there. I'm not sure how well you'd be able to get the tape to stick smoothly to the surface with those three bumps. However, if those raised bumps are worn away (reason for needing help to begin with), this trick may work just as well for them too. If someone tries repairing that style, let us know how it comes out.
