Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I would appreciate it if someone with a TEAC Reel to Reel would measure the size of the rubber reel holders. Width, Height, & Diameter of the hole. Thanks!
I have a couple of sets and will take measurements in the morning and post, if no one else beats me to it. I have a nice digital caliper; assuming you want the measurements in mm's, right?
If you have a means to reproduce these, I would certainly be interested in a set or two.
I appreciate it. I'm going to get a price on reproducing them and find out what the minimum quantity is. Hopefully it won't be too large and I can find enough folks with use for them to make it practical.
I'm going downstairs to measure them right now. If you'll send me your email address, I can even send you pictures. Sorry for the delay.
Update: I have two types - one is definitely Teac from my 6010 / 4010 machines: 38.7 mm diameter,size of holder, 7.9 - 8.0 mm diameter for the hole. This one is shaped like a hockey puck and has "teac" on the top side.
The other one, I believe is may be a teac also, has a protruding handle: 40.5 mm diameter, same for the hole. I can send pics of both if you'll PM your email.
Hope this helps or let me know if you need other measurements.
I would definitely be interested in one or more sets if you reproduce them. I have used various techniques such as "sleeving" my old ones when the hole becomes enlarged with age and the rubber hardens.
A generic chunk of rubber at a hardware store with a drilled hole works. I used door stops. Pinball machines also have a similar part(bumper stops?) that can be purchased.
