Refoaming JBL LE25 tweeters
shnaggle
Anything to keep in mind before trying to scrape off old decomposing foam from these tweeters? A particularly good scraping tool, blue painter's tape over the dome, how to best clean the surface before applying the new surrounds?
Unfortunately, one of the lead wires broke after peeling the remaining bottom adhesive circle. This was after taking care to scrape away the foam. Removing foam went ok with the other tweeter.
So, now I've got a broken, very thin copper lead wire. Can this be soldered somehow?
Congrats on getting it that far. I've tried to do this on LE25s before and failed miserably.
You should be able to solder the wire, I've done it in the past. I found it went much better with the wire and the new wire ends both stripped & tinned first.
I did this with a single strand of speaker wire to fix an 035Ti tweeter and made a write-up over on the Lansing Heritage board: https://www.audioheritage.org/vbull...-How-I-repaired-an-035Ti-Hope-this-is-helpful
Johnny, the link doesn't appear to work. I would be splicing the broken ends with an extra piece between the two?
(on edit: link is working now. Thanks!)
