SonofJames
Addicted Member
Looking for some easy tips for refreshing the finish a little on vintage Wharfedale W70's.
Thank you Kindly.
Thank you Kindly.
Retrovert, are you referring to Howard's Feed-N-Wax (which contains beeswax), or Howard's Restore-A-Finish (which does not)?
I used some light 0000 Steel Wool with Howard's to apply and polish the cabinets per Howard's suggestion on the can and in some video's I watched. Worked like a charm.
Steel wool fragments and magnets do not mix. Suggest avoiding that.
Howard's products are pigmented beeswax (soft) plus a solvent to make it spreadable, and these oxidize, lose the lustre after a few months, and attract dust. If you want to recondition furniture for an flea market the Howard's products are perfect. Harder waxes (microcrystalline) give durable finishes.
Real finishes, like BLO + poly + turpentine (see Maloof recipe) are even better.
Once a finish has been oiled or waxed that gunk must be removed before a real finish can be applied.
I've had some very nice results with Watco's danish oil on my various restorations. I also agree, no steel wool as it also can leave little metal shards in the wood grain.
Glenn
Here's an ADS 1590 with Rosewood veneer, a pair of AR-3a's and JBL 4301b's with natural color oil.
View attachment 1254312 View attachment 1254313 View attachment 1254315 View attachment 1254316 View attachment 1254317 View attachment 1254318
