I ended up with a pair of KLH Model 30s with no tweets. I acquired a couple of compatible Model 20 tweeters off Ebay and pulled the Model 30's screw-in woofers to gain access to the crossover. The front panel on these is made of fairly coarse particle board and appears to not like having the screws removed and replaced. It flakes off very easily and the screw holes can strip out. I reinforced the screw holes by squirting a whole tube of Super Glue in each cabinet's screw holes while the woofers were out leaving them to cure overnight.
The rear aluminum panels with RCA phono connectors were pulled, larger penetrations were routed out and new panels were made from 3/8" MDF/Masonite. 5-way banana terminals were installed on them and they were mounted with double-stick foam tape and screws on the inside of the cabs to keep the terminals from sticking out of the back. The foam gaskets for the woofers seem to have wandered when installed at the factory so I used a little rubber cement on the front panel between the screw holes to hold the gasket in place while the woofer was being screwed in. Also, another piece of self adhesive foam weatherstrip was applied to the inside "step" routing of the front panel to further seal things. The crossover caps were replaced with Dayton 5% film units, original fiberglass stuffing and protective cheese cloth reinstalled, RoyC's magic surround dope applied, Velcro attached to the grills and they were buttoned up.
These 30s sound kind of "brash" or "harsh" to me compared to the Model 6s that I have. The 30s do seem to have the same tweeters and some similar crossover parts to the Model 6s, minus the low-pass inductor. The Model 30 crossover looks to have been designed to act like the "NORMAL" setting on the Model 6.
Although the Web has many mentions suggesting that the Model 30s supposedly share the same woofers with Model 6, this appears to NOT be the case. The metal frame's outer flange is different and the 30 has the extra "hot cross bun" pattern of glue or something on the front of the cone. I'm not sure about the magnet size or voice coil length but I suppose the Model 30 woofers may not be as efficient as the Model 6 and the Model 30 cabinet has 1/3 less internal volume. If they ARE similar in efficiency I wonder if the woofer is contributing to the perceived harshness by being run "wide-band" ... I can't find anyone remarking about this "harshness" in the Model 17 which also has similar components, smaller internal volume and runs the woofer without the inductor ... any thoughts?
Since I just got them put back together I'm not all that hot to pull them apart again and add the inductors but I'll probably get to it eventually. I'll try to make it switchable and maybe investigate padding the tweet down a little too.
Thanks for reading and I hope there's something in this tome that you can use!
-Tim
-Tim
, so ...
