pioneervato
Lunatic Member
For resealing your drivers you can go to Lowe's (which is where I got the stuff) and look for the sealant they use for sealing metal duct work. It comes wrapped in a wax paper and almost black in color and runs about $3 as I recall. It is very pliable and is the same consistency and color (if not the exact same stuff) that my vintage pair used as a sealant. One brick of that stuff is more than enough to do both speakers.
If you ever rolled out "snakes" as a kid with clay or plumber's putty it is basically done the same way as sealing a drain in a kitchen sink or whatever. The excess will ooze out as you snug down the screws and you can remove the excess and use it for the next driver. Pretty simple to work with.
