MetalDaze
My current vinyl set up is:
Rega P3 (2016) with an Exact cartridge. Cork slip mat used with big ben weight. Otherwise the deck is stock. Run into a Rega Fono MM MKII.
Pre Amp: Parasound P5
Amp: Parasound A21+
(Currently connected) Speakers: Ohm i ; Rythmik L12 Subwoofer
The only weakness from this set up is the Exact cartridge. Which is high output and poorly shielded. Hence in my listening room where there is spurious EMI from all my equipment, old wiring in the building, high power lines running outside the window etc. I get the "Rega Hum". In the past, I've moved the deck and fono pre into another room in my apartment. Where a second system was. And all was dead quiet. Even with the volume maxed. I will be moving eventually so I'm not too concerned with the hum at higher volume for now.
I have a handful of mono records from the 60's which play but with some problems. The first of which is an original "Revolver" by The Beatles. The wax itself looked to be in good shape. Granting a VG to VG+ rating.
The second which I just picked up yesterday is "December's Children (And everyone's)" by The Rolling Stones. An original US red label mono pressing from 1965/66. Again VG+ to Ex visual grading.
Both records came from 2 different shops relatively local to me.
The Beatles record especially, tracks O.K. But all the upper register frequencies have a harsh glow of distortion around them. Especially the vocals. While the music is playing its relatively distortion free. Minus the usual surface noise etc that comes along with the medium - and an original LP from the era.
But once John or Paul start to sing, in comes the extreme "essing". I had thought it was acetate damage from being in the original sleeve all these years. Or perhaps groove damage - since this is one of the most popular bands ever, the LP has probably been played to literal death.
Both sides of The Beatles album play this way. It's relatively unlistenable. Even after washing with my spin clean.
On The Rolling Stones album, the first couple of tracks on side A have this character, but not as extreme. And thankfully, side B plays almost free of this nuisance.
I think off hand I only have 1 or 2 other LP's which are period mono. The Byrds "Turn Turn Turn" which is a white label promo. I can't remember the other.
So although I've considered it, I don't feel the ~5 albums I have out of ~100 warrant getting a mono cartridge.
So the question becomes: Does the upper frequency distortion I'm hearing seem like it is coming from a beat record? Or is it something more along the lines of stylus shape? Making it's way deeper into the groove where there isn't any actual sonic information, but just noise? And being such a high output cart- the noise gets amplified quite a bit.
I have been thinking about getting a second deck. Definitely a used vintage unit. Which has a tone arm better suited to interchange carts more easily than Rega 3 screw system.
If I went this way, I would use the Phono input on the P5 - probably with a MC Mono cart.
Any input is appreciated.
Cheers
Amp: Parasound A21+
Cheers
