Been reading about this issue since I picked up a brand new Rega P3 with an Exact cartridge. It replaces a Project Essential 3 with Ortofon Blue. The hum was pretty loud with the P3. You could easily hear it between tracks and lead in / out areas. It was going to be fixed, or the table was going to go back. I never had an issue with the Project mounted in exactly the same spot in the same system. The Project motor is mounted rear left corner, so the cartridge never got close.
Tried grounding the left RCA shield as often suggested but that actually made things worse with a ground loop. Tone arm ground is good as well. I get less than 1 ohm from my power amp ground test point to the bare metal part of the tone arm where the weight mounts.
All of this is pretty well pointless anyway with my symptoms. I get the hum as the arm is moved toward the spindle with the motor off and unplugged. This is clearly induced magnetic field noise. No amount of grounding of RFI shielding will help.
Full discloser, my table is sitting on a shelf just above a Furman power conditioner... Lifting the table up 10 or more inches and it goes away. Moving the table and power conditioners to opposite ends of the rack, hum is gone. Pure placement situation in my case. Thing is, I like how my rack is laid out. Also since the table is new, I was not willing to pull it apart for modification. Simple fix was to go to Home Depot and buy three 12X24 inch steel project panels to experiment with them as EMI shields.
It worked. I stacked the three plates and a 12X24 ceramic floor tile, just to keep them pressed flat, with the table sitting on top. Noise is a good 80% gone. I could live with it like this, but will go at it some more. Likely two or three more panels.
Think about your symptoms. Grounding or RFI shielding with not cure EMI. It needs to be blocked with a ferrous material such as steel.
