mccuskerkt
A while back I started a thread about restoring my uncommon 1960’s era Rek-O-Kut Rondine 2 belt drive turntable. Well, I fell off the map and the original thread kind of spiraled out of control, so if at first you don’t succeed, try try again.
There she is. A little dirty but was neatly tucked away in a console so it was protected from the elements
A bit closer up, and the label
The head shell is my favorite part of this whole machine. Straight out of the mid century, like a ‘57 Chevy or something.
Tension pulley and drive spindle. Messy but nothin a little soap and water won’t fix
This is likely pièce de résistance of the whole table. not quite as stylish as the headshell, although I think it’s beautiful in its strictly functional aesthetic. Would expect no less from West Germany.
I learned that this is a capacitor that tricks the motor in to thinking it’s being fed a 3 phase power supply, and not the single phase that comes through a standard 120v 60hz outlet.
Shot of the platter’s side. Heavy aluminum with some built up corrosion. Cleaning that up is the first item on the agenda.
During wet-sanding. Lots and lots of wet sanding. Started at 400 grit, then 800, 1000, then 1500 before my hands started cramping. Wish I had some sort of lathe where I could put this in and polish it that way. I’d have it to a mirror finish in no time, but a matte finish will look good too I think.
More to come, let me know what you think so far, and stay tuned! We still need to clean up the innards, build a base, and update the old wiring.
