I grabbed this at the local recycle center. It looks like a special thing. Plugged it in and nothing happened but I'll devote some time to it of its worthwhile. Any thoughts? Input?
Wow this could be a great rebuild/restore project. Go slowly and be patient for more people to chime in on this table.
The arm,cart, stylus looks like b@o
Yeah, I looked at the underside and found no nut to hold the arm pivot in so it was just hanging there. I've done bit of reading and it looks as if it was not uncommon to buy a Rek O Kut table and purchase a separate tone arm. I may need to get a new tonearm for this one. The B@O thats on it looks very rare. Not even sure I could get a stylus for it.Yup. Looks like a Frankentable...
Note the position of the arm pivot; below the surface of the platter...
It is a Bang & Olufsen integrated tonearm and cartridge
This is a real winner of a TT. The arm is only part of the equation. The cartridge can be replaced or just the stylus.
Motors on these old ROK's are as scarse as hens teeth and should be handles like a jewel. If it's an old "Pabst" it's worth over $100.
Belts are also available from several suppliers. The belt can run fast if it's the wrong one. I took me buying 3 belts before I found the right one that ran at the correct speed.
There are under neath connections that may need some refreshing. Loose wires are a problem and everything should be resoldered.
The bearing will need oil but watch for the ball inside. It will fall out as there is nothing to hold it in. If you turn the base upside down the ball will fall out and roll. It's a high quality ball bearing.
A loose connection anywhere along the wiring from the cartridge to the connectors will cause grief but once fixed it should run like a champ. Get arm setting information at "vinyl engine".
If you get rumble the motor mounts will have to be replaced as they dry out over the years. They are also available from several sources.
Good luck. My ROK I bought from an old radio station going out of business for $5 total. It is from the 50's and still going great. I use it every day.
None of this high fannootin "dc digital motor speed control golden framistat humdinger" for me. Just plain motor driven driven glory.
Got the belt back on and fired it up. It spins! Not a silent runner though. I can hear the motor whirring. Once I secure the tone arm I'll see if it makes sound.
