desertrose77
Hi!
I am recent addition to the reel to reel community. I have an Akai GX280 OD SS. It is a 4 track reel to reel. Recently it feel on its face :'( I replaced the tables and spindles,but there seems to be a deeper issue. Both motors seem to function fine without reels on them. Rewind and Fast Forward function fine as well. However, when I hit forward the reels drag against the walls of the machine and make the playback speed oscillate pretty wildly.
It seems as though tension builds on the tape delivery system which slows down the uptake reel, as the uptake reel slows that tension is relieved and it speeds up. Generating an oscillating playback speed.
Bottomline: Does anyone have experience with the AKAIGX280-OD SS? Can you instruct me on how to remove the faceplate? It seems to be a slightly different mechanism than other akai's from the GX series. Additionally, does anyone know what could be causing the playback issue?
