_GOV_
Hi all,
I picked up a Garrard Lab 80 as a project and I have a question about removing the old platter bearing/washers and installing new ones. As you can see in the picture, the original bearings are long gone, and I think one or two of the washers were gone too as the platter is riding way too low. Looks like someone tried to work on it in the past and lost the bearings and gave up and threw it back together. I have a new set ordered from ebay, so that part I am not worried about, the issue is I do not see how to get the old bearing and washers out of there as the main gear is in the way. Do you have to remove the big gear to get those out? I looked up some videos on YT, but they were of different Garrard models, and they seemed to be able to lift out without removing the gear.
Other than that, I think I have everything else working well. Everything is re-lubed and moving very freely, except the platter....which is kind of important
Luckily the idler is in really good shape and after some belt dressing applied to it, it feels great and should work fine.
Thanks
Thanks
