What could be the reason behind using 2 resistors as the oem did?
So, where would you shop for carbon comp resistors for this application? 10ohm, 1watt or 5ohm, 2watt.You might want to be careful with what you replace those carbon comp resistors with. Because they're in parallel with an inductor I'm assuming this is some type of amplifier output. Carbon comps generally have different characteristics at high freq than other types of resistors. The use of carbon comps may help to keep the output stable in this application, switching to say a 5 ohm 3W metal oxide resistor may not have the same effect. I would definitely put it on a scope if you use a different type of resistor to make sure its not doing something unsavory.
Mouser has nothing.
Have these resistors shifted appreciably in value? They do not really appear to have changed in color in the picture so minimal heating. Is there really any reason to replace them? The inductor should handle the bulk of any current through this part of the circuit so the resistors should've had an easy life.
Nothing like that.Have these resistors shifted appreciably in value? They do not really appear to have changed in color in the picture so minimal heating. Is there really any reason to replace them? The inductor should handle the bulk of any current through this part of the circuit so the resistors should've had an easy life.
+1 Yep its size. Replacing with a good high wattage shielded film (and make it fit or mod the placement) is what I would do and not worry about any RF problems.. Carbon comp is crap except like in a speaker crossover, you want cement covered or better resistors near any inductor.Increased power handling in a smaller package. Moving up to a 2W 5ohm resistor may have made it too long to fit in the space they wanted to use on the terminal strip.
