c-atle-79bay
I'm going to try and replace the tweeter on a 3 way tower with ESS Heil Elites or just the AMT module , however wonder how best to do it. My 3 ways are a 4 ohm speaker, the tweeter these would replace are 8 ohm audax that I just don't like that much, and have not lik d with past speakers owned, with an l-pad attached to it. The speakers, Chapman T7 shorties are an open frame design so that makes them perfect for the AMTs. The ESS heil elite is an add on module, which you attach jumpered off the speakers input terminals. I'm not sure of the impedance of the HEIL Elite, but the AMT Inside is 4 ohm if specs are still the same to modern versions for sale, since they use the same diaphragm I'm assuming they are.
I think my best option would be to disassemble the elite and install it in my speakers in place of the tweeter and include the elites crossover network and biamp the whole thing. This would give me the ability to adjust the AMTs crossover value as 1khz or 5.5 kHz, and to adjust there levels as desired. The mid range is a kef b110 who, according to kef is good to 5 kHz. I'm not certain of the crossover vales of the speakers crossover but am going to call the maker and ask.
-if I remove the stock tweeter would I need to replace it with a resistor, or would the l-pad suffice.
The other option is to install as above but connected to the input terminals as ESS instructions advise, although this information is anecdotal as I've not seen the instructions myself.
.-if I remove the stock tweeter would I need to replace it with a resistor, or would the l-pad suffice
The final option I can think of is to just replace the 8 ohm tweeter with the 4 ohm teeter and have it run as the speakers designed crossover point.
- this option would likely influence the speakers crossover values, but to what extent?
Of course I can just play and will do so, but trying to understand exactly what I'm doing to my poor speakers in the process st some point I'd be physically modifying the cabinet to make this happen so I'd like to rake the most sensible approach to my haibrained idea.
Thanks if yor time and knowledge FYI I'm on jury duty so lots of time to think.
