Hi, folks. Sorry if this is treading a well worn path, but here's my issue:
I picked up a turntable at thrift that ended up having wiring issues, but it came equipped with an Ortofon 2m Red which sounds just fine to my ears on another table. I decided to use it as an opportunity to upgrade to the 2m Blue stylus, so I ordered a "demo" stylus (ie, open box) from Audio Adviser and spent the last week listening to the Red while I waited for the Blue to arrive. No real issues setting up the Red, and it tracks fine.
Today, the Blue stylus arrived, so I popped it on the Red cartridge body with no other adjustments and it's skating straight across the record instantly. These two are nude and bonded elliptical, respectively, and suggest identical tracking force at 1.8g. I went back and rebalanced the arm... same issue. I raised and lowered the record with added/subtracted slipmats... same issue. Popped the Red stylus back on and it still tracked just fine. I double checked alignment of the Blue on the protractor, making a slight adjustment, and switched to a less precious record. It tracked slightly better, but was skipping easily and leaving a visible mark in my vinyl as it played.
There is a diamond visibly present on the Blue. I'm not sure what else to try, and don't particularly want to ruin any more vinyl. But I'd appreciate a little backup before I request a new replacement or refund. Did I just get a dud?
Thanks for any suggestions.
Carry on, amigos.....
