Sam1879
Member
Hi folks
I'd like to start a thread about replacing Infinity Kappa 8.1i woofer driver with more modern (sub-)woofer drivers.
The Kappa 8.2i (Series 2) have the same woofer driver as far as i know.
The "i" relates to the versions port-design, but the driver should also be the same as fas as i know.
The discussion was started by me in an other, older thread. But it would be great to discuss this topic further here.
Older discussion: https://audiokarma.org/forums/index...acement-infinity-kappa-8-2i-series-ii.691031/
Thanks for everyones support and sharing of thoughts.
The Idea is to replace both drivers of the two speakers, as the replacement driver will probably not be the same as the original driver.
I did some research and found the mentioned driver. It's ordered as i didnt found another one meeting the specs i had from the old driver. (was not much.)
Would be great if anyone shares some thoughts or technical information with me.
Hi there
I think i've damaged one of my loved Kappa 8.1i woofers (902-6236) at the last home party.
There are now unwanted noises at some lower frequencys at higher volumes, not really bad but compromising sound on focused listening.
After doing some research it's hard to find exact specs of these drivers, and replacement parts.
What i know is:
- It's 12" size
- Woofer-Crossover is at 180 Hz
- Measures 3.8 Ohm at DC, so shoulI be around 4 Ohms rated.
- Sensitivity for the whole Speaker is at 89dB 2.8V/1 meter.
-> Assumption, (Bass has seperate crossover, crossover has some little impact on efficiency) Helpful: http://www.infinity-classics.de/technik/manuals/Kappa_8.1_technical_sheet.pdf
Whole Kappa 8.1 ist:
6 ohms
RMS up to 300 watts
SPL is 89dB/2.8Vrms
As a possible option I've found the DaytonAudio RSS315HF-4 to match most of the criteria quite well.
So, under consideration i could use my DSP do adjust frequency response and i'd like to have some more low-end-bass, would you think it's a good idea or am i missing something important here?
Is there maybe even a chance to damage the crossover when using this driver?
Sorry if any purist doesn't like the idea, I'm also thinking about using original spare parts, but if there are no huge issues with this replacement, I'd prefer this solution.
Thanks for your comments. I'm gonna comment how it has worked out if anyone is interested.
Edit:
Chain: Sony SCPH-5502 / Sony PS-HX500 - Bluesound Node2i - MiniDSP DDRC22d - SMSL SU8v2 - NordOne NC500DM - Infinity Kappa 8.1
thanks so much for your support
if it's going to sound a bit different in deep/midbase up to, maybe 70 Hz i think that could be even positive, as in my setup and perception this lower area was lacking some clarity/continuity.
though i'm a bit unsure about the area above approx. 70 Hz up to 200 Hz, as the original driver here does a wonderful job and its ability to present a wonderful and "living" sound is almost incredible .
i just really don't know if a rubber surround - or other design differences - may limit the details in reproducing the dynamics or fine elements of the music in this area to much. there ist for sure a reason why arnie nudell (he was one of the masterminds behind this speaker/driver design, right?) took a foam surround and not rubber for the original driver, along with other design differences to the driver i'm planing to use as replacement.
do you have, or does anyone have experience if the reproduction in this frequency area with a similar designed (sub-)woffer driver as the RSS315HF-4 are usually perceived as dynamic, detailed, living - as with in this case the original driver ?
Or am i maybe really on the wrong track because it's just a too different design and not really tuned for this frequency area as the original driver was?
Interesting is here, the frequency chart of the dayton looks quiet aceptable and some missmatches with the other drivers (even phase shift) could be fixed with dsp-equalizing, though i dont think it's the end of the story and i dont have information about the frequency ( or q factor or other specifications) response of the original driver. Does anyone?
Photo of the original and planed replacement drivers attached.
Original:
Planed replacement:
And the crossover in the case anyone wonders
Crossover for low pass:
