Replacing a headphone jack? (C-4)
Mat86
So long story short, last summer I tripped over a headphone cable, destroying both the headphone plug, cable, and the amp's jack. I was able to repair everything involved in the crash, using some krazy glue and baking soda to get the plastic housing back together. As you can see in the pics, the snap happened right on the barrel where the threading is, and on this amp it goes through a hole on the chassis and is held in place with a hex nut on the other side so the board and HP jack are secure.
Unfortunately, I'm cursed, and (a guest) recently tripped over my cable, snapping the jack again, or at least it's loose and I know what it probably looks like if I were to open it up. Right now I lose a channel if the plug isn't in right.
Is there any way to replace this part (JK601) and get something sturdy in there? It's soldered to the board and its height matches the chassis hole so I'm concerned I'm SOL
before (and probably how it looks today):
after last fix:
Something like this..
This one is 12.5mm above the board.
Use your broken one for reference.
Do you have a dial or digital caliper ?
I dont, just tape, but dont want to remove it or the faceplate just yet since i may not be able to put it back together again
how off is the lower profile amazon one? the one you said that would need extensions soldered? (i see a lower profile on on ali that's 6.5 from base)
I'm gonna assume the 9 pin layout is industry standard?
