-reverb-
Buying, selling... mainly buying
I was a little bored yesterday; it was raining so I couldn't do anything outside. I mentally went through my audio projects in search of something small.
My Dahlquist DQ-10's has all poly caps expect for the 1 80uf electrolytic. That's a pretty small project!
I shuffle through my box of caps trying to find a couple of 80's or something that can be ganged together to total 80. Nothing. Nada.
I then remember a huge box of 10uf polys I bought from Madisound for like 40 cents each. I could gang 8 of those together to get the 80uf I need. It may be overkill - not sure if it's even in the signal path, but they are just sitting in a drawer and 80uf is 80uf regardless if it's poly or lytic, right?
I cobbled together an off-board sub-crossover with flying leads to replace the 80uf on the Dahlquist crossover. No way 80uf's worth of poly will fit in the original location. All the caps are soldered and hot-glued together to form a nice, solid block. Measuring with my meter I get 78.9uf for each one. Not too shabby.
I plan to either mount it to the Dahlquist cabinet with 4 small screws, or more likely use an industrial strength hook & loop fastener (Velcro). Here's a peek - shown beside a standard-size BIC lighter for scale.
View media item 6731
View media item 6729
Thoughts and/or suggestions?
So, I'm really curious as to how these will work out for you? Plus, please be sure to post any differences in sound that you hear after the change.
