Nestorpants
I recently was able to buy a Sytemdek IIX that appears to be an early model (steel bottom, teardrop armboard). When the power switch was clicked on nothing would happen. I researched a bit and thought it would be the capacitor but ultimately turned out to be the switch that was faulty. I've ordered a replacement switch that will be here in the next few days.
I was going to replace the resistor and caps in the power supply as well while I have it open but the issue I ran into is that instead of a resistor there's a 1 amp ceramic fuse. I'm thinking I should just leave it there and not try to fix what isn't broken. Thoughts?
I still ordered a 220 ohm 5 watt resistor just in case.
I found two 103k caps in my parts bin, will those work to replace the 01/400 phase/switch caps that are in there currently?
Also ordered a Nichicon 0.68uf 400v metallized polypropylene cap to replace the large chiclet that's currently installed.
Your help is much appreciated. Looking forward to getting this into service.
