I have read a 2009 post on this but still have a few questions. I had been mostly ignoring resistor type, etc and just focusing on value. Seems to have worked fine when I replaced all the resistors in my Pilot 500 but now I wonder. I have been reading some content on resistors and noise, also something on using good quality plate resistors. I got a bunch of resistors, offered as a vintage kit, when I needed to get to a min order from Just Radios. The 20 pack resistors do not have much info and seem small and cheap. I'll try to avoid using those. Selected resistors from them seem better.
What I think:
1. Plate resistors should be min 1W Metal Oxide, the larger size and MO construction are better for noise.
2. A number in parenthesis following a resistor designation is wattage.
3. The old, longer, smooth resistors are wire wound, maybe non-inductive wire wound (ie, a green Mallory 12,000-1 3/4" long x 3/8" diameter)
I picked up a Japanese Monarch as I liked the quirky beam triodes and I needed more practice. The circuit is below. The resistors between the power filter can caps were brown units that look like the small versions of the Mallory. It looks like both of the can multi electrolytics were replaced. The 1st 20/20 can has been replaced by a 20/40 and the resistor between the 40&20 has been replaced by a largish film 470 Ohm in series with a smaller 100 Ohm. I think the capacitance was increased to eliminate noise, which was unsuccessful. The resistor value may be somebody confused by color bands? The other resistors are the brown guys and are the 5K and 30K. There is another brown, smooth resistor (200 Ohm) between the ground of the 20/20 can and chassis ground that I don't see on the circuit but it looks original.
The 25uF electrolytics between the power tube cathodes are silver Mallory. The associated 3W resistors are 750 Ohm WW cement in lieu of the 200 Ohm 3W. I can't find the other two 200 Ohm 3W resistors for the output transformers. The headphone jack resistors are black and the wire wraps are visible below the black skin. I plan to leave all the wire wounds in place unless there is an issue during initial testing. I do plan to address the 20/40 can. I can sub individual 20uF electrolytics before I buy another 20/20 can.
Any comments, suggestions are welcome including criticisms, I have thick skin.
Looking on-line, I can find the missing WW for the electrolytic can, 2W metal film resistors for all the tube plates and 1 or 2 W metal for cathodes. I'm thinking carbon composite for grid resistors (having trouble finding those) and what I have on hand for the rest. Does that make any sense?
PS: the 200 WW at the 2nd can ground, along with the same from what looks like an OPT ground spot, may be the 2 200Ohm WW I was looking for. I still wonder at the 750Ohm Masonite WWs in lieu of the other 200Ohm 3W resistors.
Moved from DIY
What I think:
Moved from DIY
