...i had two local decoupling caps for both the driver and output stages round the wrong way, reversed the polarity on them and and changed two of the fuses on the back and now i have sound on both channels.
however, after some listening sessions the bass and treble and highs are great but the midrange is quite quiet in comparison and vocals just seem a bit dampened and no longer crisp and loud...
Update,
I have used the 9500 pre out into the 9090db and it sounds great. So the problem lies after the pre amp stage of the 9500 methinks.
anyone got any ideas what to look at first?
Were the two decoupling capacitors that were incorrectly installed replaced with new ones?
Agreed, problem lies downstream from the preamplifier stage; post a picture of your driver boards.
...it’s struggling on the highs and mids and I was wondering if I may have damaged some components on the driver boards downstream of the reversed caps...
It is possible that there was damage to the components downstream from the improperly installed decoupling capacitor, but IMO, it is not that likely. Have you replaced these capacitors with new ones? In your previous post of Oct. 28th, you state that the AU-9500 performance is "...definitely up there if not above the 9090db.", has the AU-9500 performance degraded since then?
Interestingly, your sound description of the AU-9500 matches that described for the unit prior to its restoration/upgrade; see post no. 15 which details pre and post restoration/upgrade sound impressions. To date, all three AU-9500s that have passed through my bench have sounded similar following their restoration/upgrade. May I ask what are the source and speakers that are being used with the AU-9500? How does the AU-9500 sound with headphones?...Upon some more listening time it sounds quite flat and very quiet in the mids mainly, with vocals being slightly muted. Bass and treble s are good and it’s incredibly clear with zero distortion, just lacking a lot in loudness in the mids.
I can compensate somewhat with having the loudness on and the midrange turned up to the max but I know this is not the answer...
im wondering if I have set the bias wrong, could this have such an effect on the output stages?
I did it per the manual and it is not getting hot. In fact even after playing it loud for quite some time it doesn’t even get warm
IIRC, the bias was set to ~20mA by adjusting for 20mV across an emitter resistor pair, e.g., R893 + R895.
C901, 902 - ELNA 47uF/10v CE-BPThe bi-polar capacitors C901 and C902 were replaced with 47uF/25V capacitors;
It's NON-POLAR cap.
Hi4. Replace failure-prone 2SA726 transistors.
Thank you so much,BP = bi-polar = non-polar = NP... they mean the same thing.
For the avoidance of doubt, you can see in one of the images in the first post that new green Nichicon Muse BP caps were installed in locations C901 and C902.
Well, i got it.Hi
According to Lee's statement, there are 10 failure-prone 2SA726 transistors replaced with hFE matched KSA992 transistors.
However,"Old Parts" picture shows that there are 12 transistors were replaced.
What are the code names of the two extra transistors in the picture?
Can anyone help?
Hi, I need help.The F-2030 board contains the regulated power supplies for the preamplifier
Yes, this transistor typically runs quite warm; IMO, as long as it remains below ~55°C there is no reason to worry.Hi, I need help.
The temperature of transistor 2sc680 reaches 48 degrees Celsius, is it normal?
Thanks for your reply, this is good news to me.Yes, this transistor typically runs quite warm; IMO, as long as it remains below ~55°C there is no reason to worry.
