Roger Gorke
Well-Known Member
Several years ago, I restored a Japanese model CA-1000. I predominantly listen to vinyl and the radio through a CT-600. Over the couple weeks, I have been frustrated with a poor center image and thought it was due to turntable set up issues. Yesterday, I turned on the amp and noticed a hiss coming out of the right channel. In addition, the right channel began cutting out. I went to the 'normal' culprit...a bad cable. I have done a bunch to basic testing such as switching the pre/main switch on and off, turning the volume up and all the way off, tired different speakers and speaker cables.
What I've learned...Please confirm my assumptions...
- With the pre/main switch "off", the amp is dead quiet. This tells me that the main boards are not the issue.
- Using different inputs: phono, aux, tuner, the issue stays the same. Probably not the function board. I previously replaced the usual culprits (2SC1345 transistors).
- With the volume off and still getting hiss, the problem is most likely limited to the boards between the volume controls and the "pre out" coupler: tone control, loudness, and filter.
- The 2SC1345 transistors on the tone control board, electrolytic caps, and the tantalum caps have been replaced. I used BC550C transistors and yes, I did pay attention to the different leg pinout.
- I have replaced the volume/balance control with a stepped attenuator. The original 4-gang pot was causing channel imbalance and, for those that know, a replacement pot is unobtanium. I now have no balance control but I have lived with that.
- The loudness pot has been transferred to a new PCB with new components.
- Therefore, my working hypothesis is that the problem is on the filter board. I have cleaned the switches on the filter board (and everywhere else) but not the transistors or any other components.
