Ronito6
And now for a progress report.
As I previously mentioned, I was unable to set right channel bias, and while making measurements to compare the channels I did something to the left channel which caused the same effect. I am happy to report that I have restored the ability to set bias on the left channel, (shorted TR16 replaced) and begun working on the right channel this morning.
Here is a picture of the right channel heatsink, showing the right channel OP transistors only.
And a picture of the right channel driver board - completely untouched by me. (apart from desoldering various connections to be able to remove the module).
Having taken as many voltage and resistance measurements as I could with the module in situ, I set about finding out what was wrong - expecting as with the left channel a shorted or open transistor. Knowing I could set DC offset ruled out the input FET and nine other transistors, leaving 7 to look at, I went through them all checking with my multimeter on 'diode test' and found nothing definitely wrong, but a few weird readings made me remove several to double check with my Peak Tester - all seemed good. I checked that the bias trimmer actually adjusts, and checked all diodes - all good. I checked the emitter resistors of TR10/11, TR15/16 and TR13/14, all good - and began wondering if I had some nightmare fault, like an intermittent transistor or something.
Then my eyes fell upon R36 and R37, they have the look of 'fuse resistors' (although they aren't) but otherwise look innocent enough, 390Ω - so I checked them, one measured 211KΩ and the other one was open- take a look below - the base stoppers for the driver transistors both effectively open!
I am left scratching my chin as to 'how' these came to be like that - needless to say I'll be checking the other channel as well. I learnt a lot finding these faults, I now have some extra tricks up my sleeve when troubleshooting similar amplifiers.
Anyway I know what is wrong now - but... the most irritating thing... I don't have any 390Ω resistors in stock !
More later.![]()
Nice start.
Any progress to report?
Any recent or final testing to describe?
Is it time for final words on this?
