I've spent the last couple of weeks dealing with the capstan motor.
It's all relubricated, and the sponges near the bearing, which were pretty rotted, are replaced with new felt. Cleaned out all the old oil and added new. After reassembly, I had to take the motor out again because I was getting some noise ("chugging"), and I couldn't tell for sure if it was in the flywheel section or the capstan motor. Taking off and remounting the flywheel didn't seem to help. After running the motor only with the flywheel disabled, it was clear that nothing's wrong with the motor. I took off the flywheel again, recleaned, lubricated and put everything back together. The noise is finally eliminated, to the extent that looking from the front, I didn't even realize at first that the capstan was rotating. Progress there at least.
Something that's bothered me a lot has been correct positioning of the flywheel on the shaft. I've set it up so that I can feel about 1 mm of clearance (front/back play), but to do that, it's necessary to have about 0.5 cm of the shaft protruding from the rear of the flywheel bearing. It all runs well; the issue is the protective plate that goes at the back of the capstan shaft (I believe it's called the thrust plate). The problem is that when I mount this to the two posts, I can't tighten the screws fully, because it contacts the back of the capstan shaft too strongly. It slows down rotation; if fully tightened, it can probably stop rotation altogether. I have to really back the screws off, and then the plate itself of course is not held very firm. I have looked at this section repeatedly, and redone the mounting procedure for parts in this section again and again. Everything seems to be present and where it should be. Without the plate tightened in, but just held on fairly loosely by the screws, everything's fine. I can't work out what's wrong here.
Moving on from that, I played a tape, but the original problem is still there: the tape slows down 20 or 30 minutes in. For this, I think I'm going to have to track down replacements for the motor capacitor after all. As I've now got hold of some spring scales, I'm also going to do some of the tension checking specified in the service manual.
Just to check concerning the capacitor: do I need to match the exact capacitance values (2 uF and 0.8 uF)? I have yet to locate a perfect match, but I can get a 1.5 + 2.5 three-wire capacitor with a +/-5% rating. Something similar to this, but different spuriously named company:
https://imgaz2.staticbg.com/thumb/l...F/6A/a8a3f605-f0cc-4d82-a4d2-648ec1f9fa2f.jpg
I'll be doing this at a slower pace for the coming weeks/months, because I've got about 3 audio projects on the go at once, and this deck was something of an impulse buy that barged to the front of the repair/building queue. But one way or another I'm going to get this bugger working eventually...
