Hi all, I recently bought a Revox A77 MkIII 2-track version that seems to be in good condition- besides the fact that I cannot get it to record!
Fast forward, rewind, stop all work. I had a pre-recorded 2track tape that plays fine, so playback is good too. One of the VU meters is visibly broken; the needle is stuck halfway up the meter instead of laying at rest to the far left. The other meter briefly jumps when the power is applied, but who knows if that one works either.
Here are the steps I try to record to a blank tape:
The background VU meter red dots are now illuminated.
I can monitor the source directly and hear sound but the VU meter doesn’t move at all. I can turn the record amp gain all the way up and that doesn’t change the meter doing anything, but the music gets louder.
I also bypassed the receiver tape monitor entirely and connected a 3.5mm/RCA cable to the output of my phone at full volume.
As a final test I changed the Monitor switch to NAB to hear the tape directly and turned up the playback volume and record amps to the limit and pressed record. I could hear the input very very faintly, keep in mind that if I had been monitoring the input, this would be earsplitting volume. Upon playing the tape back at that same volume I was able to hear that it was in fact “recorded” and not just crosstalk.
I went ahead and swapped out another record relay board and the behavior is the same. While I didn’t fully suspect the record relay would fix the issue, I figured I might as well try it.
Right now my suspicions have me thinking that it could be bad recording amplifiers, which would allude to the fact that I don’t see the source on the VU meters, but would both go bad at the same time? Or could it be something like the VU meter board?The manual also suggests that No Record could be caused by a bad oscillator.
What are the chances that it’s a bad record head? Before I aimlessly try different things I wanted to reach out and seek some advice on where to narrow my efforts. Any suggestions?
- Receiver Tape Mon. OUT -> Revox Aux IN
- Receiver Tape Mon. IN -> Revox Aux OUT
- Turn Revox on
- Engage the Red Record buttons next
- Press the Record and Play At the same time.
